Hi all!
Looking for a cheap, but relatively decent wireless transmitter set.
Doesn't need to be anything fancy or complicated. Just to feed image to directors monitor (documentary style).
No need to transmit 4K, but should be able to read 4K (Fuji)
HDMI (or both Hdmi and SDI)
Range atleast 10 meters
Extra
Relatively compact, lightweight, and easy mounting options.
Budget around 300 to 450
As you might suspect, I don't know anything about these things.
Just used to renting a Teradek set and plugging the cables in.
I did a bit of googling.
The Z-Cam Ipman S seem interesting at around 150 each. The atenna's do seem a bit fragile.
Also came accross a used set Paralinx ArrowPlus (with hdmiconverter) within my budget.
Is it better to go for something new in this case?
What are your thoughts and recommendations?
Extra
