Before you but a DoF adapter try this: run you're camera like a film camera...
What this means is you get the camera as close as you can to the talent to push the background back (in terms of percentages anyway).
What this means is, you do NOT use the iris to control the amount of light hitting your sensor, you use neutral density filters. Run your iris wide open (or one or two ticks closed) at all times.
What this means is that instead of spending hundreds on the adapter and hundreds to thousands more on lenses you will just spend a little over $200 on three ND filters to see if you can get to 'good enough' by using the same techniques that you will start to use when you have a DoF adapter attached. Many cameras have an ND.9 and an ND1.8 built in (like the Panasonics), buy screw on .6 .3, and .15 and use them to set your exposure.
Best of Luck,
Bob
Best of Luck,
Bob
