Bearings for my new dolly
Lor
I will be starting on finishing up my dolly track system this summer. There are a couple of things left to do but here's what I encountered at the moment. I'm trying to find these type of bearings.
I'm trying to make something similar to this:
If anyone know a place on the Internet where I can purchase something like that, I'd appreciated.
Do you know that something like that defiantly exists? Cant seem to find it anywhere.
What I would do:
Drill the holes in your section and press in a stainless steel boss, with a 15mm bore (add about 50microns for clearence and a 20mm OD. Then make a flat plate with your mount holes and a 15mm stud that slides into the boss.
Then use one of these between the plate and your section:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=1988872
And then thread the top of the shaft and stick a nut on it or something to stop it falling out. Put lots of grease on the shaft.
If you cant do that, then maybe mount a small flange bearing on either side of the section with a shaft going through.
Okay, I have been trying to comprehend your instruction and implement it but I'm not sure I understand your instruction fully. Would you mind giving a step by step instruction? Many thanks in advance.
