pmark23
Anyone tried running fluorescents from an inverter?
We'll be doing a couple corporates for two mining companies, and some of the footage will be underground.
I've done these before with battery-powered halogens, but the batteries run down too quickly -- I could only get a few minutes of useful footage before having to resurface to recharge the batteries. There's no power underground (unless you can run lights from air hoses!), and it's dark. Very, very dark. To make matters worse, the surfaces are all black. The only "good" point is that everything is wet, so there's a bit of reflection.
I have some 40W compact daylight fluorescent fixtures, and would like to try these underground running off of an inverter.
Will this work without flicker problems? Will I lose a lot of efficiency from the inverter -- enough to make me want to stick with 12V halogens?
