Jordan Berry
Hello,
I just purchased a used Brevis and I'll be setting it up for the first time tomorrow.
My humble setup is a HMC-150 + Cinevate Spacer + Brevis MP.1 + Nikon 50mm 1.4 AI.
I've got a few general questions if you don't mind.
1) As I understand it with a vibrating GG you're limited to how high you can increase the shutter speed. Is there a general rule of thumb? Can I safely go to 100 or 120? Does the frame rate change this?
2) I've read my lens (Nikon 50mm 1.4 AI) does best at 2.8. When shooting outdoors is it best to use the ND filter on the camera or to stop down the lens? I assume closing the iris on the camera would be a bad idea.
3) Is there any other rule of thumb or general knowledge stuff I need to know? Things to watch out for?
Thank you!
Best regards,
Jordan Berry
Thank you!
Best regards,
Jordan Berry
