HDWarrior
Just to let you all know I met Barry at IBC in Amsterdam last week and I interviewed Mr Green about the Panasonic DSLR Killer the AG-AF100, have a look at...
www.hdwarrior.co.uk
www.hdwarrior.co.uk
Did I read correctly that there will be an adapter soon for current Canon lenses that have no manual aperture control? That the adapter and camera will be able adjust aperture on current Canon lenses ?
If correct thats huge for anyone with alot of canon glass.
If you put a 28mm APS lens on your camera, and then pulled that off and put a 28mm full-frame lens on that same camera, you'll find that the field of view is identical. .
It's not nonsense. It's an accurate description of how things work. Read it again.Barry that is nonsense
That's the common description, but it's not an accurate description. The only reason you get "magnification" is because you're blowing up a smaller picture to the same size as a larger picture.Canon, Nikon Sigma have two types of lenses one set for full frame and one set for APS-C. You can use full frame 50mm lens on APS-C sensor cameras but you get a 1.6x increase in magnification (80mm)
There will be no problems. Any 35mm, APS-C, or 35mm cinema lens will have enough coverage to cover the entire frame.Back to my point what problems are we going to see using 35mm or APS-C lenses on the new AF101 camcorder.
Not correct, the APS-C is 22mm wide and the Panasonic is 19mm wide, so it's the Panasonic sensor that's slightly smaller than the APS-C.but I don't think the APS-C glass will work just as well as the APS sensor is a fair bit smaller than the Panasonic sensor.
Barry that is nonsense Canon, Nikon Sigma have two types of lenses one set for full frame and one set for APS-C. You can use full frame 50mm lens on APS-C sensor cameras but you get a 1.6x increase in magnification (80mm), likewise if you put an APS-C 50mm lens on a full frame camera you get vignetting. Back to my point what problems are we going to see using 35mm or APS-C lenses on the new AF101 camcorder.
Now I have had time to think it over the 35mm glass should work fine with a possible 0.4x magnification but I don't think the APS-C glass will work just as well as the APS sensor is a fair bit smaller than the Panasonic sensor.
But that's backwards thinking. Nothing about the lens image changes. It's the sensor that does the cropping. The physical sensor size is not large enough to see all that the lens is generating.when in fact it will either be cropped in or out to suit the sensor.
Exactly.I'm sorry, but I've used Sigmas lenses for different size sensors. The difference between the lenses is how big of an area the image projecting on the sensor is, it has NOTHING to do with the focal length of the lens.
Want an easy way to test this?
Take the 50mm F1.4 Sigma lens which is Full Frame and put it on a 7D.
Take the a 50mm zoom for APS-C lens and set it to 50mm and use both at the same iris.
Same FoV.
Do the same thing on a full frame camera, like with the Sigma 30mm F1.4
Sure, there is vignetting, but if it was not vignetting (as in the image it was creating covered more area) the magnification you see is EXACTLY the same.
This is why when people tell you a 50mm is a 50mm is a 50mm they are EXACTLY right.
What you care about is the diagonal size of your sensor and the size the lens can do as well, and the density of your pixels in that area. A 50mm on a APS-C will have the same FoV as a >85mm say on a FF camera, but it is still a 50mm lens and would NEVER be labeled as say a 85mm lens because it isn't, it's a 50mm lens. That calculation does not change.
This is why very small sensor cameras have normal lens sizes down to 8mm and such without fisheye and such because they only need to use a small portion of the image generated so they can make a smaller lens.
Well, that's pretty much exactly why the APS-C glass exists in the first place. The smaller the sensor area you have to cover, the easier and less expensive it is to design a wider/faster lens.in fact in some ways they work better because they don't have to cover all that extra area,
11-16/2.8 and 17-55/2.8 being great examples of great non-full frame glass
| IMPORTANT NOTICE: No media files are hosted on these forums. By clicking the link below you agree to view content from an external website. We can not be held responsible for the suitability or legality of this material. If the video does not play, wait a minute or try again later. |
| I AGREE |
Panasonic uses a 4/3" sensor which is almost the same size as 35mm (24mm x 36mm) so the full frame Canon/Nikon glass will be fine. The smaller APS-C lenses may have the same issues as you would have putting them onto a full frame camera they only cover an area of 22mm x 15mm so that means you are only using a smaller portion of the sensor which may cause issues.
