Banding issues when colour grading using HDV footage
visceralpsyche
I am colour grading my second short film right now and am running into the problem of using 4:2:0 footage from the camera (JVC GY-HD101E), captured at 1280x720x25p.
Having edited the film in PPro 2, and now trying to grade it in AE7, the problem occurs that when applying a vignette filter to the footage it results in pretty obvious (to my eyes anyway) banding issues, like there isn't enough colour channel bit depth to generate a smooth transition.
Now, I know that this is of course the issue with using 4:2:0 footage. My question is, is there a way to internally upsample the footage prior to exporting it to 4:4:4 (for example) so that colour grading it doesn't lead to banding issues like those described?
Or another way to ask the question would be, how do I take footage shot via HDV MPEG2 and convert it to a higher bit depth across all channels, so that subsequent editing etc is as lossless as possible from there on in? I know the limitations of the original capture can't be overcome, but beyond that I don't want to suffer further degradation such as the banding that is showing up on gradient filters, vignettes etc.
Thanks!
I knew there had to be an easy fix... :)
Cheers, that fixed it!
In case anyone else needs the fix, go into Project Settings, switch from 8bit colour to 32bit Colour (Float), THEN import your footage etc.
Much obliged, graymachine.
