Shot my first commercials with the LEX today, and I have to say it was breath of fresh air compared to my M2. Really sharp, very little vignetting, light efficient. Basically what it says on the box.
However, the nikon mount is of low qualtiy, compared to the mount on the M2, not to mention the mount on Nikon SLRs or macroadapters, it is quite flimsy. The problem that this causes is that it does not lock the lenses tightly enough. Anything longer than a 50mm and a followfocus will cause your lenses to shift/bent in the mount and offset the picture, making rack-focus troublesome. The larger the lens, the worse the effect. If you attach a larger zoom (80-200 for instance) you can see the lens sag/bend downwards at the mount. A lens support would help for up and down movement, but would not help for sideways movement when using a followfocus.
I hope there will be higher quality nikon-mounts available for the LEX soon, as the rest of the adapter is really great.
I don't mean to be the person who allways comes on these forums bashing Letus, because Letus and the LEX is great, but the nikon mount they offer is not., and I think people should know
