Backup raid on PC
Vinnieman
Does anyone know of software that will do an automated incremental backup of my media drive (18TB raid)? I'm using Windows 10.
On a mac, SuperDuper did this perfectly. Every night it'd run and incrementally clone my raid to an external hard drive. It could be configured so it was usable folders and files--I could plug my laptop into the backup and edit from it. I do not want a disk image or any compression. I believe this is called a clone.
I switched to PC for my main workstation about 2 years ago and have been unable to find similar software on the PC side. It seems like everything is geared toward disk images. I've been backing up this way, but with an image, I need another drive of similar size and several hours to restore a large backup.
I don't need it to be free, I'm willing to spend on quality software. I'm also investigating a NAS drive to do this, so if anyone has suggestions for those, I'm all ears.
If you google "backup software for PC" or something similar you will find lots and lots of programs that will do what you want. I have used Acronis both the commercial and personal versions and they're pretty good. Currently I'm using AOMEI backup, the free version. I also use a script that I wrote myself to do a quick backup of my media drive to my NAS. It uses the XCopy command and I run it after each editing session. I'm a bit paranoid since I lost a drive in the middle of a job.
Thanks for the reply, Otto. I have googled extensively and downloaded and tested maybe 8-10 different software brands. Haven't found what I'm looking for yet. I actually use AOMEI backup, paid version as my regular backup. It will do everything I want, just not at the same time. You can do scheduled, incremental backups, but it'll create images. Or you can do the "file sync" but it isn't incremental and can't be scheduled. I've been in touch with their support and they confirm that they can't do what I'm asking.
Does Acronis do scheduled, incremental backups to a "clone" drive--not a disk image? I've heard of them, but I think I passed because their product is called "True Image" and I don't what to create disk images.
Acronis' claim to fame was their ability to image a complete workstation. Since then they have gotten into backups. We used Symantec for the normal backups, full once a week, incremental every day. Now that I think about it we used the Acronis to make images of our different workstations, then when we bought new ones we would wipe the HD and put our own image on them. I am not sure if Acronis will do what you want simply because I didn't use it for that, but you may want to look into it.
The script I created does what you want. It will take whatever you want to back up and copy it somewhere else, then every time you run it, it will copy the changes over. You will end up with an exact copy of your source on your target. This is what I do, but my media drive isn't all that big. Also, I found a PowerShell script on StackOverflow that I think will do pretty much the same just in a more polished way, however, I never used it because my own script works just fine.
A solution is out there, it's just a matter of finding it.
