That pretty much gets it. Just mind those f-stop ratios and you should be in the clear. If you have the right angle on the back light, you can sometimes bounce it for your fill, if you are low on lights.j said:I use a 650, 300 or 200 watt fresnell, depending on the key-fill-backlight ratio I want for the shot. If can get a fresnell, get one, you will get a million and one uses out of it for other shots.
If you can't afford a fresnell, a clamp lamp with a flood or spot light (I keep 2 of each in my kit) works well. Wrap a little blackwrap (or aluminum foil) to shape the light (and keep if off the lens...) also works well.
As for mounting, sometimes a c-stand armed or double armed out, sometimes a combo stand with a "menace arm" attached, sometimes I get lucky and I can clamp to a curtain rod or use a scissor clamp on the ceiling grid.
-J
