back light - low budget option
bigteethproductions
i've had to shoot some things lately on low/no budget and little time.
I find that I'm spending a big chunk of time trying to eliminate very big shadows and I think that much of this has to do with my lack of a back light in most shots.
My "kit" (for lack of a better word) is just a few photo lights and whatever fixtures I have in a room to work with - i do plan on assembling a DIY kit based on suggestions from this forum, but will do so when I have more room to store it.
In the meantime, does anyone have suggestions as to how to back light subjects - usually people in interview type situations - without the proper equipment to back light with?
thanks.
I use a household PAR38 bulb in a practical fixture with some blackwrap. Does the trick perfectly in creating the necessary rim/backlight on the subject.
Just as a headsup backlight will not eliminate big shadows. I'm assuming you mean shadows in the background?
Back/hair light should be felt not seen (unless you're going for that effect). Dark haired people will need more. We use a dimmable fixture with a clamp on it. We also use a par38 bulb but the blackwrap sounds like a terrific idea, thanks bcheong.
bcheong,
when you say "practical fixture", for those of us not so technically inclined, does that just mean a regular light fixture?
if there aren't any normal fixtures around does anyone rig up a setting in any not too difficult way?
thanks for the responses so far, I look forward to hearing more.
Basically yes. It's a medium base household socket with a cord extension and some kind of inline switch. I carry some that I bought at a camera shop meant to take photoflood bulbs. You can also buy something similar at a home depot type store. If you know a little bit about electrical you can wire them yourself also. I've done a few with porcelain sockets to help with the heat.
In a pinch you could probably use a desk lamp. Just make sure you use the correctly rated wattage for that particular lamp!
eliminating shadows is not necessary - shadows are natural and normal and should be there - they should be primarly from one direction.
What I think you want to do is soften shadows - this can be done by adding diffusion in front of the light or a frame with silk - the softer the light source the softer the shadow
To eliminate the shadow on the background, pull your subject away from the background. Then the shadow falls prior to the background.
this is something I figured out during the shoot, but had to move my subjects to a different location within the house.
I guess its a matter of more experimenting with some light set ups when you can't move the subjects.
thanks for all the help so far though. I do appreciate it. And I am planning on putting together a DIY light kit that will be better than what I have now at least.
