Azden Field Mixer
Re: Azden Field Mixer
At the risk of sounding...Have you set the input levels on the camera itself?
It was overmodulated even though the limiter was set on the mixer and the input levels were really low on the camera.
Do you have the K6 or K6P powering modules for your mic? Other than that, it's possible there's something wrong with the mixer itself.
I found this too.
Re: how to setup DVX to record from mixer
« Reply #3 on: Oct 9th, 2004, 10:45am » Quote Modify
send 1 tone 0 dbu line level from the mixer -adjust the level on -20dbfs (the 4 white line from the last red ) run the picks on the mixer at +6-+8 at least , it still will give you 12 db of headroom for unexpected loud sond levels , you can open the mixer limmiter in +15 -16 db , if you wont to be more hooly then the pop you can open the limiters on the camera (alc -on -6dbfs start -4.5)
the -12 dbfs reference is not good for dialog recording , usially the picks can be much hier , to run the mixwer low is also not good , the -12 setting used mostly for musick or sourser which where already compreesed
