Azden 500UDR Receiver
woolbrig
Has any one used this receiver?
Can the receiver handle on two transmitters at once or do I have to switch between the two receivers?
I was thinking getting the system, but not unless the receiver can handle both transmitters at once.
According to the Azden site it is a single channel receiver. While it has multiple frequencies it can be set to, it can only be on one frequency at a time. That means it can handle only 1 transmitter at a time - two transmitters on the same frequency will interfere with each other. If your heart is set on Azden, check out kits built around the 200UPR or 320UPR dual-channel receivers. Or look farther at other brands such as Audio Technica that have a better rep than Azden.
