AVI file > Premiere Pro CS4, heavily filtered > encode in Media Encoder as ?? > AVI
I am wondering the most optimal way to get an AVI file into and out of Premiere Pro CS4.
Specifically I am wondering what's the best export type/non-compression for a file that will be converted, after rendered/encoded in Adobe Media Encoder CS4, back to AVI in the end. Since export as AVI is not an option in PPro CS4, there must be a preferred workflow.
I am also having problems with QuickTime DV Pal compression and wonder if there is a better option for my Pal project, intended for broadcast, without losing compression.
I will probably convert this file in MPEG Streamclip.
Any advice appreciated.
