AVCHD to HDV
jerfai
Hi Everyone,
I read a lot about AVCHD vs HDV and trying to convert from one format to the other... and I'm a bit confused.
I have Canon EOS 550d and the output for HD is 1920x1080 in AVCHD (.mov file).
I'm editing with Premiere CS3.
I want to have a master copy in HD of my movie in the same resolution.
I'm trying to convert my rushes to HDV which seems the best format to edit (the original file are lagging in the preview and the sound isn't good).
What I don't understand is in a lot of forums (and even on the adobe website) it is recommended to use a third party application (e.g.: cineform neoscene) to convert and then import in premiere.
however I've tried to convert directly in premiere: starting a project in AVCHD 1080 (non anamorphic), importing my rushes and then export my rushes in HDTV 1080p (MPEG2) and adjusting the bitrate.
result: I've compared the files and the quality seems exactly the same (I can't tell the difference) although the picture is slightly lighter for some reasons.
Can anyone tell me if I'm doing something wrong here?
That's the wrong way to go about it. You need to think about this in term of a lossy codec (i.e mpeg2) versus a non-lossy codec (i.e uncompressed, Cineform). With a lossy codec every generation of compression/conversion costs you valuable data. The difference might not be visible at first, but try compressing the same file 3-4 times with an mpg2 codec versus a cineform codec and the difference will become clear. Either get Cineform or work with the original format, do not try to convert to something else unless it's uncompressed or non-lossy.
