Automating Multiple Sequential Transitions
I am creating a photomontage consisting more than 100 photos.
All I do is that using the automate sequence command I apply the default transition between every photos and the default transition or transition duration can be altered according to the preference before using the automate sequence command. This is all WHAT I KNOW.
Is it possible to automatically apply multiple transition in a sequential order
i.e, cross dissolve-->wipe-->dip to black -->cross dissolve-->wipe-->dip to black-->cross dissolve-->...............
Is there a possible way to achieve this?
Do U guys even use the same transition when dealing with photomontage having a huge number of photos?
ThanX in Advance.
I don't beleive there is a way to do what you are asking. You just have to go in there manually and change the tranistions.
Look into the google photo app (name escapes me) and also photostyler, etc. Also Powerpoint can be converted into animated/video formats and what you describe is simply a slide show with transitions. If you need something fancier, you can achieve this using AfterEffects scripting.
