Auto white balance
Polaroid22
Hello,
I left my camera on auto white balance, offcourse I got the problem that my footage doesn't match. Is there a way to fix this in After Effects with a auto white balance fix for all video in the project?
Thanks,
Auto has adjusted your shots badly? Realistically, I'd have processed the clips in your editor - by just finding a common element in each and adjusting that - maybe a white shirt. I tend to use AE for complicated stuff, and do any complete clip colour/brightness/contrast adjustments in the editor, where you can easily set up split screens and then see both clips at the same time to do the adjustments manually.
If auto wrecked it in the first instance, putting it right will be a manual adjustment. Auto adjusting an already auto adjusted image rarely works accurately.
