Audition: can't hear right channel ?
firehawk
I swear this used to work?!
Using audition 3.0.
When working with an audio clip I used to be able to highlight/isolate just the top(left) or bottom(right) channel and play/listen to it.
For some reason when I try to play the bottom(right) channel I cant hear it anymore.
I see the audio meters moving.
The top channel works fine.
When I play both channels I hear them out of both speakers.
Any ideas? It's impossible to know what the right channel sounds like unless I mix and then undo.
This may mean that your speakers themselves are incorrectly connected and only receiving a mono signal from the left output of your computer. Open up your audio settings and try the pan / turning down each channel in turn there to make sure that your sound card is connected correctly to your speakers.
Thank you, Andrew.
I'm a goofball. Somehow I must have pulled the stereo cable loose from the connection just enough so that it caused the problem. Now it works again.
