Audio w. effects out of sync
scharky
I have never had a real problem with vegas until now, and even this one has a simple workaround, but still would like to know what I am doing wrong. So, on my recent 4th of july extravaganza (you can see it in the screen grabs section) I made a single audio track for an effect that I was using on some audio clips. I did a pitch shift and added reverb to the song that was playing to make it seem like it was slowing down and getting eirie. When I would go through to play this in real time, or even after rendering the timeline, the effects clip would play about 5-7 seconds late unless I started to play right in front of the effects clip. I figured it was just the computer trying to render the audio in real time, and for some reason it was slow. NO matter, I rendered out the video to MPEG2 and then the Audio to AC3 when I noticed that the effects audio was still about 6sec slow :( Since I didn't want to spend timetrying to figure out this problem, I went back into my timeline, pressed the solo button and rendered the effects clip to a separate .wav file. I then brought this back in and had to re allign the audio becasue it actually rendered it 6 sec down the timeline. Any ideas as to what is causing this? thanks
Re: Audio w. effects out of sync
I'm using V5. I just applied a reverb and (lower) pitch shift to the audio track. Thanks for taking the time to do this. If you need more info let me know.
Yeah, it happened for me, too.
Though I'm wondering if it's normal with a pitch shift. I haven't tinkered with the audio tools enough to know for sure.
