Audio Sync issues in After Effects
zns72
Don't know if this should be in After Effects or Premiere section but I have only been experiencing it in After Effects.
I am currently onlining my feature film in After Effects and I have been running into sync issues with two scenes of my movie.
My workflow is as follows:
I edit my scenes in Adobe Premiere Pro 2.0.
Import the project into After Effect 7.0 and color correct in 16 bit.
Export the sequence to TIFF sequence.
Do my final audio edit in Premiere Pro and mix down to one final wav file at 16 bit Stereo 48,000Khz.
I then import the TIFF Sequence and wav file, line them up together in After Effects and export to DVD MPEG2.
To date I have not had a problem except for two wav files that are playing out of sync.
I noticed that all the other wav files I imported into After Effects were saying they had bit rate of 487.424 Kbps but the two files that are out of sync have a bit rate of 1536.00 Kbps.
I have been exporting the wav files from Premiere at the same settings for the entire project but these two wav files bit rates won't seem to match the rest. Is there something I can do in After Effects to change the bit rate? Is there a way to control the bit rate when exporting from Premiere?
