mshakeshaft
I could do with some advice, please. By profession I am a photojournalist. Whist I use Canon DSLRs for my day to day work I was really impressed with the Panasonic GH2 video, so I have purchased one. Image quality is great but I am having difficulties with audio. I sometimes cover news events/demonstrations, where I need a compact setup. This is real run-n-gun stuff, but I want reasonable audio. Plan A was to use a Rode Video Mic Pro, but I found this is far too hot. With the camera set to 1 and the mic set to 0 or -10 db the meters on the camera still peak. In loud environments it is just not going to work. I suspect this mic is better suited to Canons where the camera inputs are less sensitive. I also really missed having any sort of monitoring and gain control. I know camera monitoring is impossible with the GH2, but mic monitoring would be better than nothing at all.
Plan B was to look at either the Zoom H4n or the Tascam DR100, but everything I have read about them suggests the Preamps are weak/noisy? So do I need separate preamps? If I am using preamps, I may as well feed this directly into the camera (Plan C).
Shotgun Mic choice: I have to say whilst the size of the Video Mic Pro had a lot to commend it, I was not impressed with the build quality. In the environments I am working in it is not going to survive. So I think I have settled for the Audio Technica AT875r with a Rycote shock mount and Dead Cat. This is short so can be camera/bracket mounted (not ideal I know).
At the moment I am looking at either the Juiced Link 454 or the Sound Devices Mixpre-D (price is very scary). The problem with both of these is that compared to the GH2 they are both HUGE. I would prefer to mount under the camera with short cables. Whilst I would like balanced XLR inputs I did consider the JL DS214, but I need phantom power and the mount is completely wrong for a small camera (what were they thinking)? Another solution could be the SD MM1, but I was a bit put off by the stepped gain control. Does anyone have any other suggestions. With these preamp/mic choices will I be able to get the gain low enough?
Any suggestions would be appreciated, I have researched myself in circles!
Thanks Martin
Thanks Martin
