lucey
When recording sound with the DVX i use input 2 with channel 1 slightly reduced for clipping and such. When i import to FCP i get a track of audio on A1 and A2 (2 tracks of 16bit per track). Obviously i get stereo tracks in each A1 and A2. Is that correct ?
If i delete say A2 track i then now have a mono track, but i still have a 2 tracks of 16 bit ?
With regards to the lower set audio Channel do you keep both A1 and A2 or do you usually scrub one, or do you adjust the level on the lower set audio. What is the general workflow used ?
