I bought a Sony PCM-M10 audio recorder to use with my Canon 550D (T2i). This was based on very positive reviews and sound samples I heard on the net. I bought it instead of the Zoom H4n because I have a beachtek DXA-6 and therefore didn't require xlr. The sound samples I heard also sounded cleaner than the Zoom H4n.
I have connected a Rode NT3 to the Sony PCM-M10 using both a simple xlr to mini jack adaptor as well as the Beachtek. I also did the same but connected to my Canon HV20 camcorder. Both setups used the exact same source and distance from the mic to the source (a track playing off my laptop). I then imported into Sony Vegas and made sure the sound level from the track was the same from the PCM-M10 and the Canon HV20.
I was hoping to see that the noise floor level of the Sony PCM-M10 was considerably lower than the Canon HV20. I mean aren't camcorder preamps supposed to be poor whereas the Sony PCM-M10 is supposed to be good. Well, there was absolutley no difference in the noise floor level between the two, to my ears, when listening to the room tone.
Is this expected? because if it is, I might as well have just used my Canon HV20 to record audio. Would I see much improvement if I used a juicedlink. I hear the preamps are good but then I also read that about the PCM-M10.
Any advice would be greatly appreciated as I'm confused and disappointed.
