Audio out of sync in 23.98 capture mode
Kiff
I finally got my video to come up using Easy Setup, I changed it to 23.98 advanced pulldown removal 2:3:3:2 then I went into audio/video settings and changed my seq preset to 23.98 capture preset to is set at the top to read:
Name DV NTSC 48kHz Advanced (2:3:3:2) Pulldown Removal my quicktime video settings under that though read Digitizer DV Video Input ZR200 Compressor DV/DVCPRO-NTSC and the FPS is 29.97 the Quicktime audio the Device is DV Audio INput First 2 channels Format 48.000kHz 16-bit 2-chan
Under that it reads capture card supports simultaneous Play through and Capture, which it should because we just bought the new quad 2.3G G5 I checked that the remove Advanced Pulldown 2:3:3:2 From DV-25 and DV-50 Sources was not checked, I checked it batch captured and the Audio still was out of sync and the High-Quality Video Play through was checked. When I change FPS to 23.98 under quality the Remove Advanced Pulldown, at the bottem cannot be checked and the computer won't allow you access. I also changed the advanced button that takes you to another page, the interlacing to progessive, because we shot 24p advanced. please help. Thanks Kiff
