Efexone
Ran into an Odd problem a few days ago (vegas 10)
After rending out to Sony AVC, the file is missing the audio track - I've checked the render settings and everything is correct - audio track is included. Using the same presets, I was having no problems last week. dragging it back on the timeline as well as checking file info yield the same conclusion - there is no audio track present. Other codecs render out correctly, including mpeg avc (it has its own problems), and I've already got a workaround setup - using a seperate program for my web exports.
No hardware changes to the machine other then some harddrives being swapped which I know would have no influence on this.
No recent software changes or updates either.
I'll end up re-installing if I cant solve the issue within the next couple days
