Audio low after exporting
rawfa
Hey guys,
I'm having an issue with the audio being too low after I export my video. When I listen to the original audio on the camera or on the Premiere timeline it's perfectly clear, but when I export it it's low in volume and quality. I've selected H264 anc AAC (sample rate 48000, highest quality). I've tried MPEG audio but I'm experiencing the same issue. I've tried selecting the option "match sequence settings" but the result is always the same.
Any thoughts on how to fix this?
Tried different audio codecs but the only way the audio stayed like it was in the timeline was exporting only the audio tracks to an mp3 file. I then imported the mp3 file, placed it in the timeline and tried to export the video but the sound was low again.
I've tried exporting via adobe media encoder and got the same issue. And now here comes the weirdest part...I've exported the MP3 along with the video file from a program called Freemake Video Converter and the sound came out low! How can this be possible??
Make sure that in the export window, under the Effects tab, at the very bottom, that you don't have Loudness Normalization checked. OR, if you do have it checked, make sure your settings there aren't the problem.
If that's not the case, double-check that the Volume, Channel Volume, and the Master are all where they should be. I've accidentally changed the Channel Volume before but couldn't see it in the timeline view because it was only showing the volume for the clip, not the entire channel.
If that doesn't work, then you might have bigger problem on your hands.
