Audio In AE
Kirk Gillock
Rebel with a cause
For some reason I can't get audio to preview (with the video) in my compositions. I can get it to render seperately (under Composition/Preview). But I would like to preview a/v together. I hope this isn't a simple question.
Thanks in advance for any help. :)
Re: Audio In AE
I have had the same problem, it seems to drop out and not play in sync. i do all my audio layup and mix in either FCH-HD or a audio app.
Sorry i couldn't be more help.
Re: Audio In AE
No problem. I should probably use Preiere Pro for audio anyway, just wanted to see if it could be done. Thanks!
Re: Audio In AE
I really don't recomend doing awhole lot of audio tweaking in AE. The audio in AE is very limited. Make sure you have your audio turned on if you want to preview it. Hit 0 to do a quick preview. I don't have AE infront of me but you should change the audio playback to 8bit 16bitmono so it can play back faster. Its really not that complicated not enless you make it complicated. I don't know if any of what I said help.
Re: Audio In AE
All i could recommend is make sure you're previewing by hitting number 0 on the numeric keypad...
Also, try hitting the . on the numberic to play just the audio and see if you're getting anything at all.
Re: Audio In AE
Thanks for the advice. I like solutions that just involve clicking one button. My brain can handle that!
