Angus_Findlay
I've got some questions about humming audio in the DVX100A.
Running the following:
The net result is that if the director wants me to provide video assist, we can't record audio in the camera. It's kind of a pain to have to unplug the monitor every time we do a take.
With the same camera, I tried to use a Samson wireless mic. It was powered from a wall wart, with the camera on battery power. Sure enough, we had a brutal hum.
I had a DI in my box of goodies, and tried connecting it between the camera and the wireless receiver. I observed the following:
Running an unbalanced 1/4" cable from the wireless to the DI, and XLR from the DI to the camera:
This suggests the following to me:
The DVX100A, despite claims to the opposite, does not have true balanced audio input. This is a fairly common offense commited by manufacturers. I work in pro audio and video, and I deal with LOTS of gear which claims to be balanced, and is not.
Unfortunately, I didn't have my monitor with me to try it out when I was using the wireless. As well, my DI doesn't pass phantom power, so I can't use it with any of my condensor mics, except my shotgun, which can be battery powered - haven't tried that yet.
I'm a bit frustrated - I don't want to have to run a heap of outboard gear just to keep the camera from humming like mad whenever I use it with a monitor.
Thanks in advance.
- DVX100A on batteries, mic level, phantom power ON.
- Shotgun condenser mic (true balanced), running on phantom
- Sony Trinitron professional monitor (tried 2 different ones), Sony mini consumer CRT monitor, or a no-name monitor
- High-quality XLR cables with Neutrik connectors. All tested.
- Ground connected: Buzz.
- Ground lifted: Less buzz, but still a bit.
- Ground lfited: No buzz!
Thanks in advance.
