Mark Seibert said:You should have a good assortment of plug-ins that were installed with Vegas. What specifically are you trying to do?
Mark Seibert said:You should have a few EQ plugs that got installed with Vegas. All you need to do is add one to your audio track, or to the clip on which you want the "telephone" effect. If you're not sure how to do that, it's the 3rd button to the right of the track name. That opens your effects. Once you have the EQ added, select it and set it to a narrow band pass at around 1k (Cut off most of the low and high frequencies). You should be able to preview this while you play with the effect. You should be able to get what you're looking for with that.
