Thanks in advance for not laughing at me, because this is probably a bonehead question. If you have a two-channel pre-amp, and you are going line out from it through XLR cables to the inputs of the DVX100, I would need to set the DVX100 to line in rather than mic in, right?
And then, would this be the right way to calibrate my levels? Set a tone generator in my pre-amp to -12 db and set the level on the DVX100 so it is also registering -12 db when I play the tone?
And then I just ride the gain on my pre-amp to get as close to clipping as possible without clipping, and that will translate to the same non-clipped level on the DVX100?
Thanks much for any advice on this setup,
jimb
jimb
