Audio Clipping But Sounds Fine
REHov520
Audio is going above 0 db on certain loud moments like explosions, music hits, etc., but sound fine. I can't hear any clipping, but the red light is going off. What problems will I run into having audio like this?
If I try lowering all the audio together by -10 db or something, then it seems to throw the mix off, ie. changes in roomtone are more apparent. I'm just wondering why it sounds fine when it peaks at 0db and the red light goes on, and if its ok to use that?
What you're seeing on the meters indicates peaking, but not necessarily clipping. Peak warnings appear when the audio is less than 1dB away from hitting/crossing 0dB. Your audio may be safe as far as recorded levels, despite the red lights.
As far as mix levels, though, peaking that high can be a problem downstream. Where are you looking to distribute this? Theater screening? Broadcast? DVD? Internet? More than one of those? Each has a different standard (loosely standardized in the case of DVD... even moreso with the 'Net).
Generally speaking, you want your standard dialog level (using your "indoor" voice) to ride around -22, with louder conversation (yelps/screams/shouts) peaking at, say, -16dB. Explosions and other peak moments can hit as high as -6dB. The dynamic range for broadcast will be much narrower, though.
Either way, the audio mix is a very painstaking part of the audio postproduction process. It's never a matter of setting the level on the whole mix and leaving it there... you have to automate the levels on each individual audio clip, but a good mix also requires careful use of compression, EQ, and limiting. FCP is not the most adept for audio mixing. STP is cerainly better, but still has its issues. If your audio is really intensive, it may be time to find a professional with ProTools to do a real audio post workup on your project.
thanks! so if I mixed everything too high the first go around, I would have to go back through every individual clip and bring it down? why can't i just lower the whole mix together to make it peak at the proper level?
final delivery will be web and dvd
