hello.
i am going to shoot a documentary using a sennheizer mkh416 mounted directly on my canon xha1.
i am trying to figure out how i can achieve the best possible sound-material from this setup. (i dont have a soundman, so i need it to be mounted on my cam)
i have experimented a bit with the attenuator and i have found out that leaving the attenuator on and set the audiolevel up when using manual will give less noise on the record. when using without the attenuator and hence setting the audiolevel down, there will be more noise to the record. ( due to camera operation...)
have anyone had the same experience? i feel like this is actually not the intended use for the attenuator? can someone clarify the reason of attenuator? (i had the impression that it is for very loud soundtakes, like concerts and stuff.)
any suggestions on how to achieve the best possible sound when using the mic on cam. i also realize that the mic will pic up a lot of cameranoise, especially when zooming.
thanks to anyone who would take time to respond...
teupaksa
teupaksa
