offbeatbryce
Can I successfully use a AT2020 XLR mic as a Boom mic on a stand above me? The shotgun I have is fairly cheap and picks up sounds in a 180 degrees access which causes lots of room echo etc
Bryce
Bryce
A side address cardioid condenser would not be my first choice for a boom, but do your own testing since you have one available to see if it works for you.
The shotgun I have is fairly cheap and picks up sounds in a 180 degrees access which causes lots of room echo etc.
Actually shotguns do pick up at 180 degrees, they just don't pick up a lot on the sides.
