whatcha think? or how about the Sennheiser ME 80...saw a couplke on ebay
or maybe Beyerdynamic MCE86 N(C)S
i know trying to cheat my way in....lol.......they are both hypers tho, so i thought maybe they would work, good deal on ebay..........no?......meaning the me80 and mce86
I...One common myth I hear continually repeated on this forum is that a hyper has reach and a cardiod does not. Mics do not have reach in the same way a lense can focus in. What we interpret as "reach" is the ratio of direct pickup vs off axis cancellation. In this respect the published polarity patterns for a particular mic is an indicator of whether a mic will function well in a given application. In this respect a cardiod (such as the MK102) can have excellent reach but, it will have a slightly wider front axis pickup pattern, which can at times be a good thing. IT IS THE OFF AXIS PATTERN THAT DETERMINES FUNCTIONALITY BETWEEN DIALOG AND ROOM INTERFERENCE.
the fact remains that different polar patterns have differing optimal working distances.
I would argue that the entire microphone including polarity, sensitivity, preamp, size of the diaphram and method of transducer decides effective working distance. The best example of this is a SM58 vs a U87. An 87 hears the entire stage. A dynamic can be quite sensitive but, falls off immediately.
The inverse square law has no bearing. It merely states that the doubling of distance from source equals -6db in amplitude. What matters is the RATIO of on axis vs off axis and how tight and consistant that pattern remains throughout the freq spectrum.
I use cardiod mics at distances of 30' on string orchestras. Sometimes the program is softer than the spoken voice. My MK102 cardiod has better reach than my MK012 hyper. Same manufacturer, same preamp and body, but tighter pattern on the 102 even though it is a cardiod.
Dialog is only one limited way to judge the workings of a microphone. Musical instrumentation, ambient, sound effects, foley, studio recording, live reproduction and speaker RTA, will give you a much bigger picture of how mics pickup in different situations.
BTW, I've been looking for info on the MK102 and can't come up with anything. Is it still current in the product line?
I'm neutral on them, to tell the truth. As I mentioned before, I already own a Schoeps so adding an Oktava to my kit wouldn't make a lot of sense but it does seem like a popular entry-level choice. The important thing is a lot of folks on limited budgets try to record dialog indoors with an ME66 or similar shotgun mounted on their cameras and a bargain hyper such as the Oktava on a boom will usually give them signifigantly better results....
I am not a fan of the Oktava hyper but, I have had some success with the 102 in like you say, "certain dialog situations." I have never done a side by side comparison so I am interested to try it for my own sake also.
