skippyfetus
Carbonite Member
As I approach the center of the American Cinematograher Video Manual, a few confusing things haunt me and I was wondering if anyone could shed some light on them.
Topic #1 -
Is DV 480i SDTV? Why do I ask? Because 480i resoltion is defined as 704x480. DV is 720 pixels wide and it uses them all. We know that it uses them all because you can see all 720 in our NLE programs.
Here are some resolutions from the American Cinematography video manual. It says that DV's resolution is 500 lines... I'm assuming it means TV lines, since there's only 480 vertical lines used in DV. It's kinda strange though because the XL1S claims 530 lines.
Topic #2 -
Quote from the manual:
It sounds like he's saying that a high end CCD can capture 9.2 stops of contrast, but in order for it to be displayed as a video signal, it must be compressed to about 7 stops... is this correct... that there can be no more than 7 stops of contrast in video? This would be consistant with what John Jackman says in his book "Lighting for Digital Video and Television". He says
Barry Green and I were debating this point because in this: http://www.theasc.com/magazine/product.htm article by Jon Fauer, it is claimed that the DVX has 8 stops of contrast. I think this is wrong... not only is it one stop more than is even mentioned in the lighting book, but it's also only two stops less than human vision. The quote above from the AC video manual suggests that a video monitor can't even display more than 7 stops of contrast.
Here's another question that arises with this discussion... do regular photographers and film users measure contrast ratio the same as video people? Because in regualar photography we count the "usable" contrast ratio... it sounds like they count pure white and pure black in video. Here's a quote by Barry Green:
and here's my response:
Topic #3 -
I found this a little odd:
From the AC Manual:
The manual is very vague and seems to suggest that HD's resolution is the reason for the diffraction issue. If that's the case then why isn't it an issue in still photography past f5.6?
Topic #4 -
From the AC Manual:
Hmm... I know that larger pixels are more sensitive to light because each pixel has a larger aperture (so to speak). I don't understand how not using part of the CCD would affect the pixels that you are using... do you? Also, because of the way the XL2 does this, it won't have the same affect will it (actually the opposite)?
Topic #1 -
The dynamic range of a high end CCD may exceed 70dbs - the ability to reproduce a contrast range of 600:1, which is a range from absolute black to two and a half stops beyond the whitest white displayable on a video monitor. It should be self evident that compression of the highlight information is necessary in order to reproduce the signal.
some film manufacturers today are claiming 500:1 on their latest, best film stock. But remember that this is an idea on the camera original; you'll never get a distribution print with that range. Video cameras haven't reached that far yet. A good prosumer camera like the Sony VX200 or the popular Canon XL1s might expose well through six stops, or 64:1. Pro camcorders like the Sony DSR-500 can consistently hit seven stops, or 128:1.
Michael tested it and found almost 8 stops of latitude. 16mm showed about 11 stops, and 35mm film showed 13 stops. The pictures are posted on his site at http://24p.com/ASC_Pictures.htm
We've got a conflict of facts. One of two things are possible:
a) Michael doesn't know how to measure contrast range
or
b) Michael is using different standards than are used in still photography and every book I've read on the subject... which is still doing it wrong.
The pictures he has posted on his website are meaningless (for this discussion) unless someone was there to measure the actual values of the subject.
Human vision is said to be about 10 stops and no film on earth has topped that yet. B&W negative film is 7 stops, color negative film is 6 stops, color slide film is 5 stops, digital SLR's about about 5 stops. There isn't a film stock out there that claims to produce a ratio of more than 500:1, which is 9 stops.
Topic #3 -
From the AC Manual:
[Because of diffraction] HDTV lenses should be operated at wide apertures and never beyond 5.6
Topic #4 -
From the AC Manual:
HDTV cameras require lenses with much higher performance characteristics. The wide screen aspect ratio lowers the CCD's sensitivity by ten percent because the area of active pixels is smaller.
