Here's what I recommended and predicted:
Mount and balance the camera inside the Gimbal.
Mount the Gimbal on top of the Steadicam. Not on the arm post, but on the stage. Exactly where the camera was always meant to be.
Mount the monitor to the Steadicam arm, and remove it from the sled. Won't need it there anymore. Put a battery in its place.
Balance the sled/Gimbal combination nice and neat just like any other, and make sure it passes the spin test. After the sled is in dynamic balance, get rid of the 2-3 second drop time. There won't be any need for it because the sled won't have to stay upright. That's what the Gimbal is for. Also by balancing the sled to neutral gravity, you won't have to fight with it in low mode. The sled will stay wherever you put it.
Now let's take it for a ride.
With the Gimbal/Steadicam combo, You won't have to watch the sled's horizon anymore. The Gimbal will take care of this for you. Re-locating the monitor on the Steadicam arm puts it directly where you need to look. This is particularly useful with Don Juan shots. No more craning your neck to get a better look while hoping you don't trip on something. Just a forward looking view with the ground in your line of sight at all times. This also works for high to low mode shots as your rig just became a jib, and you won't have to worry about the monitor "hitting" the arm like it used to.
Here's what I couldn't predict.
Pendulum weights for permanent drop down on any direction.
Joystick on-board the Steadicam gimbal to remote control camera tilt.
Panning the sled also pans the camera. The Gimbal keeps the camera level on the pitch and roll axis, regardless of the sled position. Let's you "see around corners".
May I present: The Artemis Trinity:
http://www.artemis-hd.de/index.php?id=147
https://www.youtube.com/watch?v=9rWnB90vvF8
https://www.youtube.com/watch?v=n3d2PWdG1Xo
https://vimeo.com/139576582
https://www.facebook.com/272366359629566/videos/407411029458431/
This is better than anything I could have hoped for.
