ART Dual Pre -output to stereo/GH3?
forbyfiev
Is it possible to take the 2 balanced channels out from the Dual Pre into a single stereo 3.5 TRS (for the GH3)? I'm not having much luck finding the appropriate Y cable, since i'm not sure what will happen with the ground on the balanced output.
No.
Well yes if you first unbalance the outputs with a balancing transformer, and probably also put an attenuator on the outputs since the malanced ones are probably +4 and the unbalanced are -10. That is a 14dB difference... a LOT.
I'm not familiar with the GH3 but most DSRLs only input unbalanced mic level, so as Scott stated, you would need a balanced> unbalanced transformer/adapter and attenuation... typically 50dB from a +4dB output.
thanks for the info. Any specific hardware suggestions? I see the usual DI's and such, but not the other way around....
the Beachtek looks like it would do the job. I didn't mention this, but I'd like to be able to use this on an AF100 also, with the separate xlr outs.
a yamaha mg06 would be perfect, except it requires 12v external power.
