Arri light kit ROCKS!.
Elvis
I used my Arri kit on a shoot last week And I can't belive I ever shot anything without pro lights before! What can I say lighting is everything. Talk about giving the DVX100 something to work with. Can you say sweeeeet! Thanks for all of your tips guys and gals! The produer thought I had done lights for years. This was my first official DP gig! 8)
Re: Arri light kit ROCKS!.
Elvis, which kit did you get?
I had the same reaction when I first got the Arri D1. WOW!!! Hard to for me to "get it" until I 'had it.'
Steve
Oh now Im pissed. I told my wife Ill never buy a LIGHT KIT but will probally rent or use someone eles. NOw Im getting the Arri kit! Its all Elvis' fault!
I got a good deal on it! It is the Arri softbank 1 kit.
John just tell her she will be the center of all your attention. You will need someone to practice on! ;D remember what filmmaker58 said" Buy the best, then it will only hurt once. Instead of everytime you pull it out. 8) I love that quote!
IS this the one?
Series D Softbank kits are designed for use with modern digital video cameras. The total wattage has been reduced for these more light sensitive cameras with no loss of control or light quality. Arri Fresnels with their wide flood to spot ratio are easy to control and the Video ProXS Softbank is great for interviews and the ideal size for tight locations. Try using a piece of opal or frost in the filter frame on the Fresnel to completely fill the Softbank and reduce the light level.
(44 lbs)
(1) 530100 150W FRESNEL
(1) 530110 Barndoor
(1) 530120 Filter Frame
1) 530150 3" Full Single Scrim
(1) 530152 3" Full Double Scrim
(1) 530143 ESP 150W Lamp
(1) 531300 300W FRESNEL
(1) 531310 Barndoor
(1) 531320 Filter Frame
(1) 531350 5" Full Single Scrim
(1) 531352 5" Full Double Scrim
(1) 531340 FKW 300W Lamp
(1) 531600 650W FRESNEL
(1) 531610 Barndoor
(1) 531620 Filter Frame
(1) 531650 65/8" Full Single Scrim
(1) 531652 65/8" Full Double Scrim
(1) 531658 Chimera Speed Ring
(1) 571659 Chimera Video Pro XS
(1) 531640 FRK 650W Lamp
(1) 570112 Ceiling Scissor Clamp
(3) 570051 AS-01 Stand
(1) 571194 Compact 3-Light Case (321/2x17x101/2")
Nope mine is about 80lbs. Has a 1000w. Arrilite  2 650w Fresnels and one 300w Fresnel. Barndoors and scrims for all the lights Plus a "Chimera softbox plus"  8)
Hey John,
I just got an EZ FX jib with a remote controlled pan/tilt head and six foot extension kit.
The moves you can make are so fluid and awesome.
Better warn your wife... (and loan officer) ;)
Terry
There should be a 'warning/caution' lable on the side of the camera, like booze & cigarettes. ;D
The first accessory is free.
Jezz...
And I still have one DVX to go... :P
Ah, but it keeps getting closer and closer! 8)
"Damn you Steve!  YOU MANIACS. DAMN YOU. DAMN YOU ALL TO HELL." Taylor, Planet of the Apes
DISCLAIMER
The use of gods name in vain is not meant to insult or upset.  It is merely a quote from Planet of the Apes.
Steve, "Won't you be my neighbor?" I coildn't resist after seeing you light kit list. So the only downside is cost. So what else is knew
It's not the only downside, they're also less flexible, in that you can never get a good punch of hard light out of any type of fluorescent fixture. Hard light is a vital tool towards shaping a scene, and if all you had were fluo's, you'd never have access to hard light. You can always put a softbox on a tungsten hardlight, but you can't put a "hard box" on a softlight! ;)
So, some of each. Fluo's are by far the most desirable key lights for interviews. Sticking someone under a tungsten 2,000-watt Rifa will melt their skin off, whereas putting them under a Kino Flo Diva will give you just as lovely results, but a much more comfortable working environment.
