Hi guys.
Wanted to ask about using arri fresnels. A bulb blew on my 650w last night when doing a tilt of the head (whilst it was turned on), I was under the impression it was ok to tilt or move these whilst on, but not for HMI lights. Was my tilting the cause of the bulb blowing? or just happened at the same time by coincidence.
Also when the bulb blew it tripped the circuit and blew the fuse in the plug, i replaced the bulb and the fuse in the plug head and its working fine. is it normal that fuse/circuit go at same time as bulb? The fuse is 5amp which should be fine as 250v (UK) 650w is less than 3a.
Just checking i have got everything in order or if i was making a rookie mistake.
Cheers.
Cheers.
