Joshua Cadmium
It's definitely using a larger sensor area than the standard 16x9 2880x1620. It's using exactly 3200x1800 pixels, which is easy to figure out from the math (3840/1.2 x 2160/1.2) and Abelcine confirmed it as well in the link posted earlier.
Open gate on the Alexa allows a max of 3414x2198 (3414x1.2=4096). This is taking a crop from that (the 3200x1800) and then doing the 1.2x for you in cam out to UHD ProRes. Nice workflow, and, as someone mentioned before, helpful for those who would freak if you said it wasn't exactly UHD.
Since the Alexa (and Amira) have a pixel pitch of 8.25um, the 3200x1800 would give you a sensor size of 26.4mm x 14.85mm, which would equal an image diagonal of 30.29mm. Larger than Super 35mm, but just a hair bigger than the Red Dragon at 5.5k HD (30.24mm).
Most lenses (including the Cabrio's) should have enough coverage for that (lots of testing here since Dragon's sensor is so big: http://www.reduser.net/forum/showthread.php?103766-Dragon-Lens-Coverage-Information).
