Joshua Milligan
I've been using Westcott Flex 1'x1' Bi-Color LED Panels for several years now, plus a couple of Westcott Ice Light 2's for lighting interviews and small rooms for corporate content. I've put the LED panels in soft boxes with different levels of diffusion and have been able to get pretty decent lighting that way.
Over the past year and a half, I've been going through and upgrading all of my equipment. I purchased all new cameras (FX6, A1, A7SIII), some newer lenses, a new drone, a new gimbal, a new slider, grabbed an Easyrig Minimax and a Basecamp Matte Box with filters, etc. My goal has been to completely overhaul the areas of my gear that I felt were kind of lacking.
Now I want to upgrade my lights. This is the last area I want to upgrade from (I already had great audio gear and support gear), so I want to really do it right. I've always felt that my Westcott lights were great to travel with and that they were "good enough", but I don't want good enough anymore. I want to have exceptional lighting for my clients.
The type of work I do is corporate, commercial, small doc, branding content, and some remote projects for Discovery. The types of clients I work for include eBay, several colleges, a large engineering and mapping firm, plastic surgeons, dentists, insurance agencies, commercial and land real estate companies (on the marketing side), nonprofits, etc. I tell you all of this so that you can get an idea of the type of work I do so that the discussion I want to have has a basis to work off of.
For my new lights, I've been drawn to Aputure. I feel that point source lights make sense for me because they allow for a wide range of flexibility and usually pack a punch in terms of brightness. Aputure makes some great point source lights that are well built, bright, well priced, and that have a lot of options in terms of modifiers.
So far over the past couple of weeks I went ahead and ordered two Aputure LS 300X's and two LS 60X's. My thought was that the 300X's would make for great interview lights being that they are bi-color and that the two LS 60X's would make for great bi-color rim lights/hair lights. I got two of each for times when I'm interviewing two people 60 Minutes style which I do on occasion. I also thought the 300X's with Light Dome II's and/or Lantern modifiers would make for great lights for shooting corporate work in offices, small buildings, etc. In addition, I'm about to order a Spotlight Mini Zoom for one of my 60X's that comes with 15 gobos that I can use for interesting lighting for commercial work or for projects where you're showcasing a product.
In addition to those lights, I also picked up a couple B7c's (the app controlled light bulbs) and a couple of MC's for practicals. I also was tossing around the idea of getting some SGC Prism 60 RGBW 2' tube lights to have on hand for accent or practical lights when shooting corporate projects or the occasional music video I get. The SGC lights, like the practicals and point source lights from Aputure, can be controlled through the Sidus Link app which is super useful.
Now I want to pick out a big light and that's what I wanted to ask opinions on. With the 300X's, 60X's, practical lights and tube lights, I have a lot of areas covered. From interviews to lighting for b-roll in corporate offices, I will have several bi-color or RGBW lights to allow me to match my surrounding if needed and to light and get interesting shots. Where I'm lacking though is a light big enough to fill a large room or to fight the sun, whether that's fighting it indoors with windows or outside directly.
Aputure has three large point source lights: the 600X, 600D, and the upcoming 1200D. All three are pretty bright. For me, I plan to only get one, so I wanted to get input from other users here on DVXuser as to which would pair the best with my kit. This light needs to be bright enough to help me combat the sun as much as is reasonably possible, manageable to use by myself when working alone, and it has to be a good fit for shooting into my 6'x6' scrim with super silks using a book light method, or to bounce off of my 6'x6' unbleached muslin reflector fabric.
The 600X to me makes a lot of sense because it's bi-color which all the rest of my lights now are (some even being RGBW). This would give me full control of every light I own. The 600D on the other hand would give me about 30-40% more output and since I'm needing a bigger light to either light a large space or to fight the sun, the additional output from the 600D also makes sense. The only issue with the 600D is that gelling it seems to be quite the task and appears almost impossible when using a Lantern 90 or Light Dome II / Light Dome 150 modifier. The 1200D is not available yet and looks pretty large, so I'm not sure that's something I would enjoy working with alone.
In a perfect world I would just get a 600X and a 1200D and have a grip or assistant with me at all times to help set them both up when needed, but that seems like overkill for me right now. As such, if you were me, which route would you go to round out this kit?
Thanks for your input!
