Otis Grapsas
Carbonite Member
I'm working on a digital cinema camera and I'm implementing the white balance scheme. Ideas on the subject and what would make the implementation more usable in a production environment would be very helpful.
Some thoughts:
Auto white balance using a card, makes color correction in post difficult, because white balance result depends on user experience and the same correction cannot be applied to a large number of shots. Material shot using fixed white balance presets on a scene should be easier to correct because it will have more uniform and less extreme errors.
White balance presets can have any number and be presented in Kelvin for matching standard home, office, studio and natural lighting situations. This can cover 2900K to 7000K.
White balance in camera uses gain on some of the R,G,B elements. So, a scene lit with 100watt household bulb is at 2900K and will need 12dB of gain on blue in a given camera. If an extraordinary quality camera has a 66dB s/n, the blue s/n will deteriorate to 54dB which is a typical broadcast figure for s/n and nothing to write home about.
An alternative is to white balance using filters. This is the engineering approach to the problem that maximises noise performance. Stacking an 80A and an 82B will take 2900K to 5500K which is the natural balance of the above camera. There will be a loss in exposure of course, but if the camera already needed to be stopped down in order to handle the red elements, the camera could still get good exposure with the filter losses, even at 0dB gain. That would require no blue gain and would produce the ideal 66dB s/n on all three channels. In higher lit situations, no gain would be required because the losses can be covered by opening the aperture.
I understand that practical reasons will lead most users to use in camera white balance instead of filters.
Some thoughts:
