Disco Robo said:I love it how everyone says you need to use a broadcast monitor for cc etc., Nobody is watching your footage on a broadcast monitor so dont sweat it. Make sure that you use the display calibrator assistant, take your time, and dial it in. Everything is lcd these days anyways. When was the last time you saw a high def CRT? Good Luck.
An LCD HDTV is still very different from an LCD computer monitor. So is an LCD based production monitor like the Panasonic 17 in. Computers display colors in the RGB color space and TVs dont. If you expect your footage to be viewed only on computer displays you're ok - somewhat. Dont forget, Macs and PCs display color in different gammas as well. It is not the LCD panel that makes the difference so much as the signal being fed to it. That is where the MXO box comes into play. It takes the YUV information from Final Cut for example and uses LUTs to convert the color information to RGB in order to display accurate color for broadcast.
Yes you can calibrate your LCD monitor to get you in the ballpark but it is still just a guess at best.
Yes, LCD based production monitors are becoming the norm, but they are not LCD computer displays. Again it is the signal and the processing of the signal, not the LCD itself.
I use the Gretag calibrator too, for print production work where they were meant to be used, but I dont expect them to make my Cinema Display into a reliable, standardized production monitor. I just doesn't work that way.
It all depends on how much it matters to you and what your end use is. I can't hand off my work to other professionals and say "there, thats close enough i think." and expect them to fix it if it's not.
