Anyway to save Title preset in Premiere?
Huy Vu
I've been making Titler rolling credits from scratch which can be a bit of a pain especially since it's usually just a matter of replacing the names. Is there a way that I can make up a title template preset, save it and then load it up in other projects?
Yes, piece of cake: after you design your title, close the Title tool, select the title in the bin/project panel, and the select File > Export > Title. You'll have the option to save the title as a standalone file with a PRTL extension, which you can import into a different project. Once it's imported, you can change it and it will become part of the project, leaving the original title template alone for later use.
Thank you sir, I will try that.:thumbsup:
