Anyone here know DVDSP3 ?
Mortimer
This seems to be more active then the dvd compression topic so I thought I would try here first.
Having a button problem with this software, basically I need to be able to see some sort of cursor or pointer select the diff. butons on the menu, or at least have the buttons highlight or change color when its on that button in the menu. Right now I can work the buttons but I have no idea which one I am on in the menu.
Thanks for your help
usually i start with one of the apple template buttons that highlights in a way i like. then i just edit the font, color, button position, etc. it's fairly easy to do. if you need to edit highlight colors and stuff, you select the button in the menu window, and then you can change everything in that window in the lower right, whatever they call it. it has a tab with all of the highlight color info. (you have to be working in the extended or advanced configuration, not "basic.")
Hey thanks for the reply. I will give that a shot and make sure I am working in the extended or advanced configuration.
Thanks.
