Any way to amplify sound of a Peavey 100-Watt Messenger Portable Audio System?
Can you give some detail on what you're using the system for? What kind of space you're using it in, etc.
You're not going to be able to do anything to boost the current system, but if you give some idea what you're looking for, I can give some recommendations.
Well, it does have line outs (both stereo and mono-summed), so if you only need extra sound occasionally, you could look at renting another system of some sort to augment it. But if you're wanting more power all the time, then getting something bigger is probably going to be easier in the long run...
