ElectricMayhem
Hey everyone,
I'm going to be building myself an edit machine from the ground up within the next month or two. Right now, I've been pushing my 1.6Ghz Intel Centrino Duo Processor and 1GB of ram in my HP laptop for all of my freelance editing work. [I have a pretty decent but old tower at my job where I do a majority of my stuff... but for anything outside of work... well my set up is shameful]
I use it for Avid Media Composer, Adobe Premiere CS3, After Effects CS3, Photoshop/Illustrator/Encore. It works, but I know I can't survive off of it as I want to progress into bigger and better things. I'd like to some day start working in some 3D modeling as well.
That being said... I'd hope not to spend more than 2 grand if at all possible. I don't know if anyone on here uses a similar set up of software and could recommend anything to me as far as hardware goes. CPU/Motherboard/Graphics Cards/Etc/Etc.
From what I've gathered from looking around, Intel seems to be the way to go if I want to go to go high end, with the i7 or the core2 extreme quad. (Either of which could blow half/two-thirds of that budget) Probably rock a WD Raptor drive as my OS drive... or a similar variation. Probably will avoid a 64bit OS ... because, well, I have no clue what's going on with it. So I'll cling to a copy of XP Pro before they leave the shelves for good.
I'm a novice as far as the processor/motherboard harmonious meshing goes. The last thing I want to do is get a great processor with a shitty motherboard.
So it is with humility that I ask if anyone has any recommendations, especially since I've not been terribly active on the forum since I joined. Thank you to anyone who can recommend anything.
Sincerely,
Matt
Sincerely,
Matt
