Mommaerts
Hi All, Can you look at this frame grab and tell me what the issue is?
http://www.progressivedesigns.ca/roonie.jpg
I've imported and edited an entire sequence and when I output it using Compressor I get some frames that look "interlaced" (I don't know if that's the correct term, I'm referring to the offset in horizontal lines when there's quick movement, in this case his hands) my guess is that it's because I shot using the PRESET 1 on the DVX which I beleive is 60i. Is it normal for my final output to have frames that look like this? If not, are there any suggestions on how I can fix this?
thanks SO much for your attention,
(M)
(M)
