Hi,
I got a CRT viewfinder from the very first HD-Cam from Sony (HDC-100 from 1986), which I want to use with my XH-A1.
This viewfinder has no designation, it was used as a secondary viewfinder for the HDC-100 (which had a HD viewfinder by default) but the CRT´s resolution (from Matsushita) is SD.
Now, everything is prepared now, but I get the same "garbled" image through the composite input,from the Canon or any other source:
The image looks "combed" or "hacked" with thick scan lines and is repeated several times along the horizontal axis, but is relatively steady on the vertical axis.
I fed the viewfinder with several formats, NTSC-SD and PAL-SD and also HD1080-50I, but I always get the SAME result!?
I have the circuit diagram and board layout, there are two boards in this viewfinder called VF-9 and VF24.
But I do not know, wether the signal of the cam was delivered in SD or HD to the viewfinder.
Any ideas?
All the best,
Frame
Any ideas?
All the best,
Frame
