fuzzybabybunny
I'm looking for something that I can use to record audio with via bluetooth.
I'm envisioning a transmitter that accepts a mic as an input, then a receiver that has a 3.5mm TRRS plug or whatever that can be plugged into your phone, laptop, etc.
I purchased a Sena SMH10R, which is a wireless comms device for motorcycle riders, but it can transmit audio via bluetooth. It can, for example, transmit audio via bluetooth to a GoPro bluetooth receiver. I can easily solder and replace the stock mic with a better one. The problem is that Android phones will only record incoming bluetooth audio at 8kHz and 32kbps, which is basically the very old HeadSet Profile. Modern bluetooth can support audio at much higher rates. I want to bypass all of this by just having incoming audio go through the headphone jack of the phone. It's not optimal due to the multiple conversions of the 44.1kHz+ signal back and forth between analog and digital, but anything is better than 8kHz.
So I'm primarily looking for a bluetooth receiver that can output the audio it receives into a 3.5mm plug, to be plugged into a recording device.
